Old 60's Porsche Tech
captainlewis's Avatar
oil temp check best location with infared tester??
Not sure about my temp gauge readings. Where is the best place to check oil temp with infared tester out on the road. I want to check the temp against the gauge so I have a good bench mark in the future, thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 05-23-2009, 06:53 PM
In a nutshell, you cannot get anything reasonable accurate using an infared tester to read oil temps ............
Further, your oil temp guage only samples temps from one spot inside the engine and I can assure you there are places where its a lot hotter than what you see with the guage.
My suggestion would be to first confirm that your sending unit matches the guage. Sometimes we'll use an external sender and guage to compare with although the senders must be installed in the same place for this procedure to be accurate .
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-23-2009, 08:37 PM
