Looking for some suspension input
hey all
have a 73.5 tub and alot of sc parts the goal is a hot rod that will see some track time local DE stuff here is what we are thinking 23f 27 rear torsions off sc 22mm weltmeister sways all aluminum stuff off sc tailing arm, steering box, konis front and rear monoballs@ trailing arm neatrix front and rear 16 7&8 fuchs more to come not sure of torsions?? any input apreciated thanks
tull87 cab ![]() 80sc Targa track car ![]() 73 project ![]()
PRO Motorsports
Sounds good, except for the torsion bar sizes.
21/27 is a better ratio. 23 front would match better with 30 or larger in the rear. 23/31 is a good balance. Konis are great when new, but wear out pretty quickly. The adjustability is nice, but the Bilsteins are a better long term set-up. If you change the set-up down the line, the Bils can be revavlved to match. The Koni Sport rear shocks come with bump rubber that is too long for where you will set your ride height. Cut 21mm or so off the solid end, not the segmented end of each bump rubber. AFAIK, Neatrix only makes rear spring plate bushings, not front a-arm bushings. The closest thing is the street-hardness poly-graphite bushings. Better yet, just get the Elephant Racing poly-bronze, and be done with it. Well worth it.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Non Compos Mentis
My 3.2 powered 1973.5 has 23/31 T-bars. Great combination for autocrossing, not as harsh on the street as I expected.
kinda figured the torsions were a bit off was going to try to use as they came off sc but looking to get this set up right
