-   -   G50 Issue - Monkey Needs Help (http://forums.pelicanparts.com/porsche-911-technical-forum/476336-g50-issue-monkey-needs-help.html)
Porsche_monkey 05-27-2009 06:07 AM
Originally Posted by Peter Zimmermann (Post 4685472)
Probably a synchro, but I'll bet it costs lots less to fix than the clutch replacement. G 50s are over-engineered and almost bullet-proof, it might need nothing more than a couple of synchros/sliders.
I hope so. I know the clutch prices are crazy.
I will tear it down in the fall and post the details.
Thanks everyone for the 'input'. I don't think I can solve this with out tearing it apart.
Hendog 05-27-2009 09:23 AM
Meanwhile, at least change the trans oil. Do you have limited slip diff? This will determine your gear oil selection: either 75W90NS or 75W90. The NS is for a NO SLIP diff. I use redline in mine but I've also read good reports from Mobil users. It's worth a try.
Porsche_monkey 05-27-2009 12:40 PM
I have no idea. How do I check? (aside from doing a burnout and checking for twin black marks)
Paulporsche 05-27-2009 01:43 PM
If you jack up the rear so both wheels are up, you put the trans in N and spin 1 wheel . If the other spins the same direction you have a LSD. There also is probably a code visible under the trans hatch behind the front seats, but I don't know what it is for LSD.
Peter Zimmermann 05-27-2009 02:23 PM
If you have a white sticker, about 3"x4", under your trunk lid, look for "M 220." That'll be the option code for LSD (40%).
Porsche_monkey 05-27-2009 02:53 PM
I knew that. :rolleyes:
Maybe it used to have that. I think it disappeared during the 'tub and hood straightening phase', but I will check tomorrow.
Thanks.
Porsche_monkey 06-11-2009 12:06 PM
Update:
1. I do not have limited slip, no code under the hood. If I rotate one wheel on the hoist the other wheel turns the opposite direction.
2. Drained the tranny today. The oil was very blue/green and I am thinking (hoping) it was Swepco. Did not appear to be synthetic.
3. Very little in the way of metallic debris on the magnet. Just one tiny piece from what looks like a chipped dog tooth, really really small.
So, I will dump in some synthetic tomorrow, and see what happens....
