G50 Issue - Monkey Needs Help
The Monkey is stumped. :( First time with a G50 car and now this:
P-car #2 ('89 G50 cab) has been sitting for about two years. After getting it started again I now find I can not get third gear when I am driving. Sitting at idle the G50 will go right into third no problem. I do not think this issue was there when I parked th car two years ago, I think it is related to the long time it spent idle. Not 100% sure of that though. I am guessing the synchro has jammed up (rusted while sitting?) and is preventing me from shifting 'on the fly'. I am tempted to drain the fluid and look for 'evidence', maybe put in new synthetic fluid and see what happens. Suggestions? |
I would say draining and filling with new gear oil (synthetic) is the right place to start. Otherwise I have no wisdom to impart...
I replaced the fluid on my recently acquired 89 Coupe with Quaker State 75W140 synthetic and find it takes around 10 to 15 kilometers of driving before it starts to shift smoothly... After the oil warms up it shifts better than the original OEM oil !
Being from Canada there's lots of it at your local Canadian Tire ... lol |
As it only happens when driving I would look at the tranny mounts also. The oil change would be a (fairly) easy 1st step.
Have you tried to put the car in 3rd, at idle, and drive away in that gear (from a stop) to make sure it really is in 3rd gear?
Please consider the above post about 75W/140 trans oil, that is not permitted for use in your car. You will be better served sticking with 75W/90 synthetic gear oil - I prefer Super Three Star Kendall synthetic, if you can find it in your area. |
Let me know if you need some shop assistance.
Will it do into 3rd if you "double-clutch'? That would indicate if the syncro is good or bad....
As stated above the 75W140 gear oil is not correct. 75W90 for sure.
You may also want to take a look at the shift linkage items circled in the diagram below. A problem with any of those could result in poor shifting. Items 2 & 10 are common wear items. Good Luck, Andrew http://forums.pelicanparts.com/uploa...1243352747.jpg |
So as of now:
- I can start in third, no issues there, third gear works from a stop. - I can not shift into third on the fly, even if I double clutch. I can feel the gears grinding if I try to force it. Prognosis? |
Failing clutch fork or shaft?
Unrelated? |
Sounds like badly damaged gear engagement teeth. If you can get them aligned when at rest, but cannot at speed, seems like the teeth are boogered. I have a hard time describing what the operating sleeve/teeth assembly looks like. It's not what most people recognize from the 915. The G50 Borg-Warner/Getrag gear engagement system is quite different in it's design
RE: clutch action occurring in the top 1/2, that's common. The G50 clutch engages really high on the pedal travel. |
I guess this winter will be G50 education time. Cha ching I am guessing for parts.
I can last the summer without third gear. |
Just curious, how many miles are on the trans?
Given the symptoms, can you shift into 3rd on the fly by matching revs to speed? Coming out of 2nd, let the throttle off ever so slowly so the RPM's just drop off little by little. Keeping pressure on the shifter would allow the trans to engage in 3rd at the correct RPM to ground speed.
If this works, the trans is fine, the clutch is not. |
| All times are GMT -8. The time now is 11:15 AM. |
