-   -   Injectors are not "vibrating" (3.2 motor doesn't fire) (http://forums.pelicanparts.com/porsche-911-technical-forum/476338-injectors-not-vibrating-3-2-motor-doesnt-fire.html)
bigpino 05-25-2009 01:49 PM
Did an engine drop for several oil leakage repairs and transmission revision. 4 years later after putting it back the motor cracks, but doesn't fire/start. I went through the troubleshoot list of the workshop manual and 2 things are not adding up:
1) Injectors are not vibrating. I've measured a block signal on the terminals, but no vibration noticeable with bare fingers or screwdriver on the top (next to electrics). How noticeable is it anyway? Is there an other way to check. At least one spark plug was wet of gasoline.
2) The resistance for both speed and reference sensors between terminal 1 and 3 is not measurable (my meter 20Mohm max). Spec's suggest >100Kohm though, but bigger than 20M is like not connected at all. Is this an issue?
Other things I couldn't check are:
1) Fuel pump pumps, but can't measure the pressure. A line was burst and I replaced it, so I assume the pressure is ok. Not sure about the residual pressure though.
2) Did not put speed/reference sensor signals on an O-scope.
3) Air flow sensor is provided with 4,6V instead of 5? Air temperature resistance is fine though.
4) Altitude switch, evaporation control, and airflow valve potentiometer not measured. Last 2, not sure how to.
5) Fuel is 4 years old. Could be too old.
Other guys think there is no compression (cracking is almost effortless) due to the extensive stand still. So they think we should tow and jump start in order to get the oil everywhere. We did not do that yet.
Any other suggestion to check?
Tyson Schmidt 05-25-2009 02:00 PM
Are the cluster grounds for the injectors properly attached to the intake manifold near the #1 intake runner?
dentist90 05-25-2009 05:15 PM
First time I put my motor back in it wouldn't start. Cranked just like it should but wouldn't fire, not even a sputter. Started checking everything systematically... spark, fuel pump, etc. I was so frustrated I could have cried.
Then as I started to take off the air meter housing I noticed that I had missed plugging in the 4 pin connector at the firewall. Turns out the car won't start without this!
Thought I'd mention it... just in case you've overlooked the obvious like I did.
bigpino 05-25-2009 05:46 PM
tyson, yes i attached that ground cluster. It is two sets of a couple brown wires.
dentist90, do you mean the aluminium air mass meter? mine has a 5 pins connector on lid side (facing to the back). Only 4 of the them are used. Is that the same connector? if so, there's only one way to plug it in. So how did you misplugged it?
rsscotty 05-25-2009 06:10 PM
I think the connector that dentist90 refers to is the 4 pin connector on the shock tower area on the left side looking in the engine bay. Easy to forget.
rick-l 05-25-2009 06:18 PM
Do you have a spark?
whiteSC59 05-25-2009 06:24 PM
smell fuel. if it smells more like laquer than gas, dump and start over. usually fuel left over 1.5 yrs turns yellow and is better for thinning paint than starting an engine.
88-diamondblue 05-25-2009 07:10 PM
I did the same thing in forgetting to plug in the injection connection. The connector on he very right side of the picture next to the shock tower. I would also get rid of the old fuel and put a new fuel and fuel filter in.
http://forums.pelicanparts.com/uploa...1243307227.jpg
dentist90 05-25-2009 07:22 PM
Originally Posted by rsscotty (Post 4683614)
I think the connector that dentist90 refers to is the 4 pin connector on the shock tower area on the left side looking in the engine bay. .
That's the one. The harness (thick brown bundle with rectangular plug at end) can get under the weather strip at the firewall and gets lost and forgotten. Good luck.
http://forums.pelicanparts.com/uploa...1243308115.jpg
bigpino 05-26-2009 06:56 AM
I got a very blue spark, Rick. And indeed the only harness connector "in front" of the engine was already connected. I can see how one can easily forgot.
I going to change the fuel, just to be sure whiteSC59.
Currently, my biggest concern are the injectors. No vibration what so ever in both key position "engine on" and during cranking. I expect it would vibrate during cranking. One guy suggested to put 12V directly on the injectors to see if they work. What do you guys think?
rick-l 05-26-2009 07:12 AM
No
They are low impedance injectors and rely on the controller to reduce the current after they open.
Do you have any starting fluid to see if lack of fuel is the problem?
bigpino 05-27-2009 08:49 AM
Ok, no 12V on the injectors:). Sounds like current controlled instead of voltage. Anyway, we gonna replace of the fuel with fresh fuel. After that we going to tow and jump start it, just to get the oil all around the engine and hopefully it will build compression and start.
DW SD 05-27-2009 10:17 AM
injectors seem to get stuck closed after long durations of non - op. Why don't you check a few other threads. I think some have used 9V batteries or even some tapping to free up stuck injectors.
Can you cycle your fuel pump without cranking? I've used a jumper lead to run it. You will hear the fuel circulating and the fuel pressure regulator opening and closing. If you can check that off the list, you can focus on the injectors.
cranking will build oil pressure without towing, etc. That sounds dangerous, too.
Doug
bigpino 05-27-2009 11:13 AM
I can jump wire the fuel pump relay, I've done that before. I haven't notice pressure regulator doing its work though. How can you tell?
Having looked at the mechanic schematics, tapping the injectors seems too crude though in my opinion. Anyway, I will search the forum for stuck injectors in the mean while.
MURF 05-27-2009 11:30 AM
Injectors
Injectors could be stuck..we use power probe to 12v one terminal and ground the other..just tap them no long term voltage..see if they click,...we have been very happy with
southbayfuelinjectors.com..try them cheap and fast turnaround..they send you flow chart of all the matched injectors
bigpino 05-27-2009 12:06 PM
Ok, just a quick 12V "brush" huh. With specs of 2-3ohms, it's quite a current . . . At least you say one can actually here them clicking.
It's hard to find a thread about solving stuck injectors other than replace them. If somebody happen to stumble upon it, please let me know. Just in case. southbayfuelinjectors.com has no porsche category, so don't know what the equivalent is. I believe I've got MFI (3.2).
bigpino 05-27-2009 12:35 PM
One more thing. How can one tell whether the fuel pressure regulator is working? Without a fuel pressure meter.
MURF 05-27-2009 05:13 PM
injectors
try removing the fuel rails with the injectors installed.bypass the dme relay to run the pump hot wire the injectors 1 at a time to check the spray pattern or you can remove the coil wires [disable ignition ]and check the spray pattern with engine cranking if you have no injector pulse this will be a waste of your time..did you try noid lite in the injector wiring harness plugs? we just finished 87 cab that sat for 9 years and we had s.b.f.injectors.check clean and flow equalize all the injectors $20 each..new seals pintales..look and work just like new....murf
ps install fi injector gauge between rail and regulator to check presssure
MURF 05-27-2009 05:17 PM
injectors
2nd thought..you can also upgrade your bosch injectors to the new series 3 style no metal inside..do not stick ever and have multiple port spray pattern for better partial throttle response...do a google search and check out new technology..murf
rick-l 05-27-2009 06:54 PM
Since you get a repetitive hot spark you know the speed and reference sensor are working. Now you need to know if the peak and hold circuit for the injectors is working. Without a o-scope the only way I know to check that is with a noid light (do a search for noid) or go to Radio Shack and buy an LED and a 50 ohm resistor.
One side of the injectors is at 12 volts and the other side is switched to ground in the DME to control them. They are all driven in parallel by one driver in the DME. You could also measure resistance across them because if one is shorted it disables all of them.
bigpino 05-28-2009 04:33 AM
I've grepped a LED and some resistors and assembling my own "noid light". For the people who want to do the same:
Note the current is about 200mA@50ohm, so the resistor should be able to handle at least 2W (standard electronics resistor can only cope with 0.25W. 50ohm = 8 x 400ohm in parrallel).
Going to test tonight . . .
TroyGT 05-28-2009 09:34 AM
Noid light kit can be had at autozone on the cheap... and you'll have a set to use on all your cars. Mine came in a hard red storage case too. Saved me.
-Troy
bigpino 05-28-2009 04:34 PM
Update: not running yet.
I was indeed surprised how cheap noid lights are, but I had the components and it toke me a few minutes to assemble.
Here is what happened last time:
Replaced fuel and hot wired fuel pump to mix residual fuel with fresh.
Checked injector signal with my hand made noid light B-) -> OK
Hot wired one injector -> only noticeable if one put finger on it. Is it really that faint?
I incorrectly installed the ignition rotor (180; wrong phase). Oopsy:) Corrected that.
It has run very briefly with start pilot several times. But it does not always start with start pilot. Why is that? Once it back fired so hard that the rubber joint after the air mass sensor came off.
Odd observations:
Fuel pump is leaking a bit.
During cranking -> oil pressure ~2 bars. Is that not a bit high?
During cranking -> rev. meter very nervously moving between 500 and 2000. We use a very big battery, so you expect fairly constant revs. But 2000, that's impossible right? I would say it will never exceed 1000. Speed sensor broken or distance too small/big? Anyone?
Additional question
Are the valves hydraulic? One guy thinks the valves do not close. But than again it ran pretty sweet several times with start pilot . . .
Starting to get a bit hopeless now . . .
bigpino 05-29-2009 08:08 AM
Anyone?
MURF 05-29-2009 08:12 AM
Injectors
You will have to remove fuel rails with injectors installed to check for actuation and spray pattern..caution disable ignition to prevent fire
bigpino 05-29-2009 08:24 AM
ok, so cranking rev. of 2000 is not odd?
rick-l 05-29-2009 08:39 AM
What is a "start pilot"?
Edit: If start pilot is starting fluid, it might be time for a pressure guage since you have injector pulses.
bigpino 05-29-2009 08:42 AM
Spray into air intake and the engine can run even without gasoline. I believe some people even got that work with brake rotor cleaner. It's like a combustive gas.
bigpino 05-29-2009 08:44 AM
Murf, it seems hard to connect the injectors to the system when they are out. It there a trick without dettaching the other things?
rick-l 05-29-2009 08:50 AM
When I jumpered 12 volts to the fuel pump up at the fuse panel to check for leaks I could clearly hear fuel flowing through the system in back. Want to try that?
bigpino 05-29-2009 08:56 AM
I already hot wired the pump several times. I'm sure it pumps. It even burst one of the fuel line before. So the pressure is there, it's only hard to tell whether the pressure regulator is doing its job. You got a trick to check it?
DW SD 05-29-2009 09:06 AM
Answers inline in italics
**are you hearing the fuel pressure regulator open and close?
**I don't think it is faint a faint sound. The injectors are probably stuck. Did you try using a 9V battery to get them clicking? others have used that procedure
**Are you sure you have the firing order correct? I didn't think you could install the rotor backwards. Isn't there an index notch?
**what is starting pilot? Ether / starting fluid?
Odd observations:
**sounds dangerous! Why not fix it before you have a fire?
**no, doesn't seem high for cold oil
**seems normal. the needle bounces under cranking
**the fuel pump would not turn on if the computer does not see movement from the speed sensor. At this stage, I'd think the crank speed sensor either works or it doesn't. Are you sure the fuel pump is turning on during normal cranking? I think it should be since you are seeing spark. There would be no spark if the crank speed sensor were not working. The computer won't send spark without the crank speed sensor.
Additional question
**They are not hydraulic, but solid lifter.
**he is wrong. not until 1995 did they have hydraulic lifters
Answers above within your quoted section.
bigpino 05-29-2009 09:34 AM
***Not very very sure, but while i was hot wiring the pump the other guy said he heard irregularity, suggesting is was regulating.
***not 9V but 12V from the harness connector (also checked if 12V was there) and then brushed the contacts of the injector (to keep connection very short).
I incorrectly installed the ignition rotor (180; wrong phase). Oopsy Corrected that.
***Got the order from workshop man. : 162435 with 1 at the marker of the housing.
***I pulled out the rotor unit to replace the o-ring. Did valve adjustments in the mean while and put the unit back afterwards. There is an index notch (crankshaft "pooly" under fan), but it passes twice when the engine rotates once, hence, 180 degrees.
***yes, starting fluid. Some use brake cleaner.
Odd observations:
***We found out later (at the end of the night).
***Ok, that's good the hear.
***Check.
***Ok, needle indication during cranking makes no sense. Check. And yes, pump runs during cranking.
Additional question
***Check.
***As I mentioned before, I adjusted the valves according to the workshop man. It was a bit colder than the recommended room temp. (it was less than 10 degrees Celsius). Would that make much difference? Anyway, it ran quite well with the starting fluid, so I would say: the valve are ok.
My answers also in the quote. Thanks for the point by point answer.
DW SD 05-29-2009 09:42 AM
Nutshell.
I assume injectors, but could be fuel pressure. As for the fuel pressure regulator, you can feel it opening and closing. It is on the driver's side fuel rail in the back. Turn on the pump and feel it open and close. Or test fuel pressure on rail test port. 38 to 39 psi, I think.
Someone found some Buick fuel injectors (I think) which are interchangeable. Do a search on injector, rebuild and you'll find the thread. They were much cheaper than the Porsche version, but also still made by Bosch. Forgive me if my memory is failing.
Seeking out other threads will get you to the answer on the injectors and how they either got them regoing or the injectors they used to solve the issue.
Doug
bigpino 05-29-2009 09:59 AM
Ha, don't apologize Doug. You and the other guys are really helping me a lot. It's a bit hard without some tools like pressure gauge, but alternative quick tests sometimes do fine enough.
I will concentrate on the the pressure/regulator and injectors.
MURF 05-29-2009 10:15 AM
Injectors
The injectors are held in with clips that will hold them into the rails!!if you don't verify good spray pattern then you should plan on sending them out to be flow tested and cleaned..then you will know for certain they are good..you need to remove all the potential problems to get it running properly
bigpino 05-29-2009 06:03 PM
update
tested fuel pressure regulator by putting my finger on it while jump wired the fuel pump relay. There was no noticeable switching going on so I assumed that thrre was not enough pressure. So either pump is not sufficient or regulator is broken.
In the meanwhile, I checked all injectors by jump wire them to a hard 12v. They are all snappy except the one I previously tested (murphy's law). Tapping on while brushing the 12v on it got it released again.
The other guy wanted to try one more time, while we concluded that fuel pressure regulator was not working. But lady luck was smiling upon us. It started and ran smooth.
Apparently, all the injector were stuck and 12v test had unnoticeably released all the other 5.
Thank you guys for yet another solved case.
DW SD 05-30-2009 06:42 AM
Nice! Congratulations! Probably worth exploring the FPR further. But it sure must feel nice to hear it fire!
Doug
Zeke 05-30-2009 07:27 AM
That may explain why my car runs on 5 if I leave if for 3 weeks or so.
bigpino 05-30-2009 01:10 PM
Yeah, it was really great feeling. I already gave up after the injector test and was calculating the costs of fuel pump/regulator, but the other guy ask me to crank it again:).
Milt, I read in an other thread that one can actually hear the difference between a worn and 'healthy' injector. By hot wiring one at the time (I did it in place, i.e. only harness detached) they should sound crisp and snappy. You can clearly hear the switching, so as for me in the initial case: if you have doubts whether you hear it then it is not working.
Can't mention enough, thanks guys.
