Fitting size question
What fluid fitting (plug) has a 13mm diameter across the male threads, 11.2mm across the female threads and has a 1.25mm threadpitch?
Is that a 12mm, a 13mm or some other imperial size? This is for a plug on a swedish (opcon/autorotor) supercharger. Trying to order the right fittings to plumb in a pump and cooler with the transmission. thanks |
Any help out there please?
Did you notice if the threaded section is tapered or straight?
Straight. Pulled out the Engineer's Black Book...1/4 BSP maybe? Earls has a part number to adapt to -8 but not at Summit...
Yes, 1/4" BSP. Major diameter is 13.15mm with 19 TPI. (Don't know about 1.25mm pitch.) Straight threads require a sealing ring though.
| All times are GMT -8. The time now is 11:10 PM. |
