Wer bremst verliert
JohnJL's Avatar
Fitting size question
What fluid fitting (plug) has a 13mm diameter across the male threads, 11.2mm across the female threads and has a 1.25mm threadpitch?
Is that a 12mm, a 13mm or some other imperial size?
This is for a plug on a swedish (opcon/autorotor) supercharger. Trying to order the right fittings to plumb in a pump and cooler with the transmission.
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-26-2009, 04:47 AM
Wer bremst verliert
JohnJL's Avatar
Any help out there please?
Old 05-31-2009, 03:48 AM
Did you notice if the threaded section is tapered or straight?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-31-2009, 04:56 AM
Wer bremst verliert
JohnJL's Avatar
Straight. Pulled out the Engineer's Black Book...1/4 BSP maybe? Earls has a part number to adapt to -8 but not at Summit...
Old 06-01-2009, 06:53 AM
Yes, 1/4" BSP. Major diameter is 13.15mm with 19 TPI. (Don't know about 1.25mm pitch.) Straight threads require a sealing ring though.
Old 06-01-2009, 07:28 AM
