tranny case sealer?
putting the front cover back on my 915, I have a new gasket, but I would guess I need some 50 dolla 1oz tube of super sealer as well, any recommendations? or what did you use?
thanks!
Old 05-26-2009, 07:05 PM
Almost Banned Once
sc_rufctr's Avatar
Curil T... http://www.germansupply.com/home/customer/product.php?productid=16441
- Peter
Old 05-26-2009, 07:29 PM
barney911rs's Avatar
If I recall it's just a paper gasket correct. When I did a lot of work on 901 transmissions, we used Permatex Aviation Form-A-Gasket sealant. Here is a link.
http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_sealants/auto_Permatex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
brush a light coating on both halves, put the gasket in and put it together,
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 05-26-2009, 09:57 PM
Bird. It's the word...
Fishcop's Avatar
I just did this job and used Threebond 1104 ($10)
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-26-2009, 11:15 PM
Slumlord
Porsche_monkey's Avatar
There are about 100 effective solutions. Anything posted above will work. As will Loctite flange sealant for about $10.
I like the Loctite product. You can usually just peel the gasket off and re-use it when your tranny has to have a 'minor repair' the day after you install it. I have some experience with this issue.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-27-2009, 05:28 AM
Less brakes, more gas!
euro911sc's Avatar
Locktite 571 (I think that is the number... what ever we use to seal engine cases) The 571 seeps into the paper seal and I have not had any leaks since... except out of the service plate after I replaced it. Any of the above would be good. Just remember to spread it very thinly on the seal with your finger and thumb as you do not want to add too much dimensionally to the case. Not as important with the nose cone, but more so with the other sections.
-Michael
P.S. This is a Chris Bennet trick I learnt when he helped me rebuild my tranny... for the 3rd time!
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-27-2009, 06:59 AM
Slumlord
I meant this one... Loctite 518
http://www.ellsworth.com/imagelibrary/jpegs/400/LargePics/51831.jpg
http://www.ellsworth.com/display/productdetail.html?productid=1005&Tab=Vendors
84 Cab - sold!
Old 05-27-2009, 12:44 PM
Peter Zimmermann's Avatar
Curil T. Very thin coat on each side of the gasket. Use lacquer thinner or MEK to clean the sealing surfaces. Q-Tips are your friend.
Keep the Shiny Side UP!
Pete Z.
Old 05-27-2009, 02:29 PM
Zeke's Avatar
If I wanted to go back in there at any point, I'd use Hylomar.
Old 05-27-2009, 04:39 PM
K&W spray coppercoat. let it tack up before squeezing. thicker sealers on thin paper gaskets like these cause the gasket to break and squeeze out with the sealer, so consider that.
206 637 4071
Old 05-27-2009, 05:09 PM
Slumlord
Like I said, 100 options....
84 Cab - sold!
Old 05-27-2009, 05:33 PM
I think I am gonna buy and try them all!!! only thing is, should I apply 10 thin coats or like change sealants every 3 inches....
seriously awesome, thx peeps.
Old 05-27-2009, 06:00 PM
