HFR_Racer's Avatar
Please identify my strut brace...
Thank you..[
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 07-02-2009, 09:54 PM
HFR_Racer's Avatar
The strut brace was installed by the previous owner.
This brace appears to hold the top of the strut in a rigid fashion. I've read several threads here that indicate that this is a bad idea and that mono-balls are the correct method. Everyone please chime in.. If I should change this then I want to do it before I break something.
Thank you,
HFR_Racer
Thank you,
HFR_Racer
Old 07-02-2009, 09:57 PM
Looks like a Weltmiester and they do work.. It is a good thing, you won't break anything. I have them on all but one of my 911s..
Old 07-02-2009, 10:56 PM
HarryD's Avatar
Agreed that it is a Weltmeister. I would modify it to allow the top strut spindle to move as the factory intended.
Check this thread: Weltmeister Strut Bar upgrade project
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-02-2009, 11:07 PM
I'd concur with Harry,...... at the very least, the upper mounts need modification to allow the strut inserts to rotate freely and not simply inside the strut housings.
Honestly, its not a good design at all and the WEVO Camber King as well as the Elephant strut braces work far better without the associated binding issues that the Weltemeister ones have.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-03-2009, 12:42 AM
I have contemplated adding a brace and in doing so I have been sucked into Weltmeister's marketing material. Their research makes sense to me,..the idea that there is more deflection around the rubber strut bushing than in the actual deflection of the body. But I also can understand that the Weltmeister design restricts the rotational movement. Is there an option for those who like the idea of retaining the dampening power of the rubber, as opposed to mono balls, but still hold the strut spindle in its place?
Rich
1988 911 coupe
1970 911t project
2012 Golf R
Old 07-03-2009, 11:07 AM
Max Sluiter
Flieger's Avatar
Uhhh... the monoballs
They allow rotation but not deflection. The weltmeister restricts the deflection too but no rotation. The rubber+weltmeister is not any more compliant.
Old 07-03-2009, 01:26 PM
