Designer King
Paulporsche's Avatar
Left Front Signal Fix
I didn't see this in the first 100 search items so I thought I'd post it just to get the data in.
My left front signal light stopped flashing. All others worked and so did the emergency flashers.
I swapped in a new bulb and checked the fuse and relay. All seemed fine but the fault remained.
Remembering that the flashers are wired w/ the headlights, I opened up the H4 trim ring and found that one wire was down to 2 strands @ the spade connector. When I touched the wire it broke.
I renewed the wire @ the connector, replaced everything, and the flashers now work perfectly.
Simple fix; simple thread.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-02-2009, 07:21 AM
