BP8EVX engine 911 T 2.0
Hello
i have an engine 911 T 2.0l (weber 40 idtp carbs) rebuilt like the original expected the pistons because i put six JE pistons 80mm ratio 9.5 with cylinders in biral.
i put NGK BP8EVX plug.
is it good model?
thanks
jerome
Old 05-31-2009, 03:35 AM
304065's Avatar
Jerome, no. BP8EVX is a platinum racing plug, $14 each. Platinum plugs don't work in 911s.
Get yourself the regular BP7ES, they are under two bucks a piece.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-31-2009, 05:17 AM
bp8evx
hello john
thanks for you answer.
can i put a plug more cold than the original bp7es like bp8es because i have more compression ration than origin (9.5 with je pistons 80mm instead of 8).
what happened if i put a bp8evx or bp7evx ??
or do i must put the bp7es.
thanks
Old 05-31-2009, 05:59 AM
