Plug Vacuum Advance?
I've got a 76 911s with a 1978 3.0L engine & 915 transmission with California emissions equipment. My question is, should the vacuum hose to the distributor be detached and plugged while setting the timing?
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
"Limping in the right direction is always faster than running the wrong way"
Old 06-01-2009, 06:20 AM
Yes.
Old 06-01-2009, 06:58 AM
Thanks for the quick reply. Confirming...detaching the vacuum and plugging is the procedure for setting the timing at idle...how about when conducting the dynamic procedure at 6000 rpm?
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
Old 06-01-2009, 07:13 AM
Detached is for the dynamic test....6000rpm should be at 24 to 31 degrees. At idle, it does not need to be unplugged.
Old 06-01-2009, 07:17 AM
Great...again thanks for the quick reply and the clarification!
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
Old 06-01-2009, 07:23 AM
