Rough idle diagnosed as intake leak on #2
Before replacing the gaskets on 1, 2 & 3 as recommended by the tech, does it make any sense to loosen the barrel nuts on #2 and try re-torquing them first to see if it fixes the leak?
Thanks! |
bump
the gasket below the plastic spacer usually gets sucked in, so tightening doesn't help.
Guess you goota' know the gasket integrity,..only one way to do that,..and while you're in there,....
Best, Doyle |
| All times are GMT -8. The time now is 11:57 PM. |
