Throw it on the ground!
Rough idle diagnosed as intake leak on #2
Before replacing the gaskets on 1, 2 & 3 as recommended by the tech, does it make any sense to loosen the barrel nuts on #2 and try re-torquing them first to see if it fixes the leak?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 06-01-2009, 09:34 AM
bump
Mark
1987 911 Coupe
Old 06-01-2009, 04:36 PM
the gasket below the plastic spacer usually gets sucked in, so tightening doesn't help.
206 637 4071
Old 06-01-2009, 04:58 PM
dshepp806's Avatar
Guess you goota' know the gasket integrity,..only one way to do that,..and while you're in there,....
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-01-2009, 05:29 PM
