throwout arm
After installing transmission ,I find I can not adjust cable, I get tire rotation in all gears, weither clutch is engaged or not. I am thinking throwout arm is did not align with center of throwout bearing,and clutch is engaged all the time.Before I remove engine to check this possibilty, I am hoping someone may know if my guess is right. Thanks for any help Norm
Old 06-03-2009, 09:46 AM
Peter Zimmermann's Avatar
Uh...
Year & model?
All original-type components?
Install trans - why was it out?
Can't adjust cable? Explain...
With the car raised have you used a flashlight and mirror to look at the T.O. fork/TOB through the hole in the upper half of the bell housing?
Keep the Shiny Side UP!
Pete Z.
Old 06-03-2009, 10:00 AM
Komenda Fan's Avatar
Like Peter said, you can check the alignment of the throwout bearing and Fork through the top of the bell housing. Do the tires rotate due to parasitic drag (can you easily stop them from rotating with your hands?)? IIRC, you should be able to move the throw out fork back and forth inside the bearing race and here it clicking against it in either direction.
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 06-03-2009, 10:36 AM
