Door Frame window removal?
Hi All,
From the pictures I've seen, when you remove the door frame, the triangular windows at the leading edge seem attached.
Are the windows removable?
Is it different with early "chrome look" door frames?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 06-03-2009, 05:12 AM
Adam the front triangular window does come out together with the door frame. I didnt remove it when I pulled out my door frames recently but do recall that once the door frame is removed the attachment screws for the triangular window are obvious.
Old 06-03-2009, 05:05 PM
Once you pull all of the screws out (watch for the hidden ones) it comes out as one and unless you want to, there is no need to remove the triangular glass.
This pic is from a '78:
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 06-03-2009, 05:18 PM
Thanks for the replies...
The reason I ask is because I'm looking to purchase some "chrome look" trim the same as the one pictured above. The piece i'm looking at has the factory tinted green glass as pictured above. I was just making sure I can put my OEM glass (from 86 3.2) into the earlier frames.
Just confirming I can do this?
And also, how much does a full set of chrome look trim go for nowadays?
Thanks a lot,
Adam
Old 06-03-2009, 06:19 PM
