droopy tailpipe
The tailpipe on the muffler does not seem to be sitting up high enough. I checked all connections and hangers, can't find the problem. Am I missing something? What else can I check? Seems like the muffler is sitting at a slight angle. It's a Dansk muffler. btw, I realize the rear valance is trashed, came that way from the PO, I will be replacing soon. If anyone has a extra valance PM me.
1988 porsche 911 "CE" cabriolet |
I'd say loosen the straps and pull the right side down. That will raise the LS. I don't know what the actual cause might be. Could be bent as a part of some damage caused by the PO.
Take the muffler off to see, or shim it down from the topside. |
Northern Motorhead
Had a hard time aligning both tailpipes to be at the same height when i installed a Fabspeed
dual outlet muffler recently... What i found is that you can loosen the cat converter at the manifold and you have some "give" that will let you raise your mufler while still bolted to the cat then retorque your cat bolts while prying up on your muffler. In my case i also installed an MK premuffler with all new stainless hardware so i was able to fine tune the tailpipes to even heights using that method ! |
Northern Motorhead
Just to add a little note... i had to cut and grind ALL the bolts in order to remove the original cat so don't bother trying unless you have a high speed air grinder with a thin cutting wheel and some rotary files to grind off the nuts which will allow you to drive the remaining bolt shanks out !
Ah, yes, you will have to loosen the bolts going up the driver's side, too. Good point.
That looks bent to me.
I have a stock muffler that drooped. The last time I had my engine out, I noticed that the mounting bracket was broken. Maybe this is part of the problem?
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M§ion=EXHmuf&page=5&bookmark=17&part_number=930-111-151-01-M100
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I have a valence from an SC in real nice shape (white). I'll PM you price.
Thanks, Rich
-Rich- 1984 911 Track 1985 911 Track/Autocross |
Check your motor mounts and rear support..
+1 on motor mounts. One of the guys at the autocross was talking about how his tail pipe was hanging low. He check everything and found the motor mount bolts were loose. A few more miles and something bad would have happened.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
