Jetting thoughts
Hi!
When I set up my of Weber 40 IDT 3C for my 2,2T motor I was advised to go with: 125 Mains 180 Air 55 Idle F26 ET 30 Vents. I stayed with 185 air and emulision tube F2 that I already had and followed the rest. It works ok but running quite rich on idle, slow and under light loads. Shall I try 50 idle jets instead? What is the difference between emulision tube F2 and F26? Is F2 ok for me? |
Take a look through this thread. It should clarify everything for you.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Thanks! Alot of interesting info there, but I'm still little comfused, it seem important but just consist of inconsistent numbers... I found these tabels in the book Weber carburetors by Pat Braden from HPBooks;
![]() ![]() It says F2 for IDT 911T enigine size 2.0 anyway, appropriate for 2,2 as well? I read in one of the treads you linked to that a guy "Ttweed" used F2 on a PMO-carb'd 3.4 motor and he said that that will give him less fuel delivery at the mid-range and more at the top... |
I'd be careful extrapolating jetting from a 2.2 by starting with a 3.4. There are too many variables which are different to make a generalization useful.
Looking at my database of carb settings, it looks like the following resulted in a happy 2.2T: 32 Venturi 120 Mains 180 Air Corrections 55 Idle F1 Emulsion Tall Secondaries
