TARGAJACK's Avatar
Strange noice for the doors
Hi guys, I changed motly every little bushing, sticker plates, higes, door stays, pins....and there is still the TIK when I open or close my doors ( both side ).
It happens halfways on each side.
I am probably not alone to hear the TIK noice.
TY
Jack
Old 05-12-2009, 05:15 PM
Regis turd ab user
It is most likely your door stay hinge pins.
Old 05-12-2009, 05:48 PM
On my car it is the hole in the arm of the door stay through which the hingle pin fits. It is worn so that the hinge pin doesn't make a good friction fit and there is a lot of play. It clacks everytime the arm is yanked. I seem to recall that DarrylD fixed this on his 912 by welding up the hole and re-drilling it.
Steve B.
1972 911t
1999 328is
Old 05-12-2009, 07:07 PM
Porsche Crest
That tick is the stops built into the door stay so that your door will not fling all the way open when but pause at that point by presenting a resistance, this also slows your door from opening which helps to prevent you from hitting adjacent objects with your door or when parking curbside opening it so wide that a passing car eats it.
The tick is the sound of a perfectly working door, and the ting when it closes means its adjusted correctly.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-12-2009, 07:14 PM
(the shotguns)
berettafan's Avatar
so the 'tick' (i'd call it a creak) is SUPPOSED to be there?
Old 05-12-2009, 07:16 PM
yes, I think actually it is two clicks, hold on I'll be right back.
Old 05-12-2009, 07:19 PM
Thumbs up Confirmed...Two Clicks
Yep two clicks, one at about 30 degrees and the other at about 60 degrees from open. As they get worn the clicking will tone down and eventually become less audible, but you will still notice a resistance.
Do your new door strikers make a ting sound?
Aloha, Shane
Old 05-12-2009, 07:23 PM
Regis turd ab user
I believe the "ting" when closing the door is the retaining tab for the wire harness for electric windows. Cars equiped with this option have the tab folded over and around the wires and the metal tab no longer creates the tone.
Old 05-12-2009, 07:47 PM
I'm referring to a different "ting" maybe it is a "ping" but I am sure it is different than the ting you are referring to as my car has all manual windows and locks, and it makes a distinctive ting.
I initially noticed the ting in a video that was posted on this board of a guy in Europe who had completed a very cool restoration of an early car, and he specifically pointed out the ting of the door as it closed, I wish I could find that video.
Old 05-12-2009, 08:55 PM
Calgary944's Avatar
Jack, have you felt the sheet metal where the door stay attaches to the door and checked for a tear in the metal? That area is notorious for fatiguing over time.
Terry R.
'81 911SC Targa
Old 05-13-2009, 09:41 AM
Porsche Crest Listen to the harmonics at the end, sounds like a tuning fork
Old 06-08-2009, 10:13 PM
