Question Burnt ignition rotor
I have a 77 911S- 2.7L.
The engine has a miss at idle and sometimes I hear a kind of rattling sound from inside the distributor...especially if Im adjusting the timing. There is very little play in the distributor shaft.
I took a look inside and found a rev limiter type rotor. There seems to be a hole burnt in it close to where the tip discharges...looks like there was some kind of epoxy covering a wire that leads to the contact lead.
I checked with my ohmeter and I do not have continuity between the discharge contact tip and the center contact
Anyone seen this before?
Old 06-14-2009, 08:44 PM
Max Sluiter
Flieger's Avatar
There is a resistor in the rev limting rotors. When you use high-performance ignition systems with higher voltage, the resistor heats up too much, burns, and melts the rotor. Dig out the resistor and solder in a piece of stout, high-quality wire.
Old 06-14-2009, 10:25 PM
Wer bremst verliert
JohnJL's Avatar
Search on "rotor" and "modification" its well-documented here.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-14-2009, 11:41 PM
Almost Banned Once
sc_rufctr's Avatar
What ignition are you running? MSD, Stock... or other???
- Peter
Old 06-15-2009, 12:12 AM
Also, someone is going to post to use the 912, non-rev limiting rotor. This is still a RESISTOR rotor. The 911 and 912 both spec out at 5K ohms. I was just in the parts shop with my multi-meter last weekend, checking them all out. I ended up having to do the rotor mod...
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 06-15-2009, 07:02 AM
