si77's Avatar
Quarter of a tank, but fuel light on?
Hi all, just got my car (1986 Carrera 3.2) back from a load of work. As far as i know the tank, gauge or sender wasn't touched. The car has approx 1/4 tank of fuel, but the reserve light keeps coming on, which do I believe?
Cheers
Si
Old 06-16-2009, 04:50 AM
It is very easy to pull the sender. It is right on top of the tank. Just pull the sender and check to see if things move around smooth.
Old 06-16-2009, 05:37 AM
Wer bremst verliert
JohnJL's Avatar
The sender for the level and the light are separate and somewhat arbitrary. They indeed have separate circuites to the dash and you can disable the warning light by disconnecting the "W" connection on the tank.
The other question is does 1/4 tank warning bother you?
You can adapt to it, disconnect it, or insert a resistor or resistor potentiometer to adjust the voltage/current to turn on whenever you like.
1/4 seems reasonable unless you are racing in which case you likely are converting to a cell in any case and have other gauge issues.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-16-2009, 06:06 AM
si77's Avatar
Cheers for your help. Will have a look.
Do you think it does have 1/4 tank in it?
cheers
Si
Old 06-16-2009, 06:09 AM
It is possible that you are on "reserve" - tap on the glass with your finger and see if the needle moves. Maybe the gauge is stuck aty 1/4.
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 06-16-2009, 06:24 AM
