Early 19mm Spongy Brake Pedal
I replaced my 19mm M/C about 2 years ago and 8K miles ago. It came with a 1 year warranty. All calipers were rebuilt at that time and flex lines replaced. I remember it having a stiffer feel than prior to rebuild, but not a true completely firm pedal. Pads are Ferrodo 2500 and fluid is Motul 600.
Since then, I have had hot brake fade at DE's 2 times. The system has been bled several times over the past couple years, but I have never regained a firm pedal. Thinking that the flex lines were damaged, I replaced them with the stainless lines. The pads, rotors, fluid were also replaced and I even added the Ti brake shields about 1K miles ago.
What's my next move? Rebuild the calipers again? I can't find any leaks. Others have suggested a new Master Cylinder. Some have suggested upgrading to a 23mm M/C.
The pedal feel now is:
first 1 inch feels like mechanical slop
then 2 inches of modulation
then 2 inches of sponge - 1 inch at normal leg strength, 2 inches performing leg press.
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 06-13-2009, 09:49 AM
Sounds like a bad seal inside the MC, IMO. You say you "never had a true completely firm brake pedal," which may indicate a bad internal seal from the get-go. Given that you have refurbished the components up to the calipers--and they don't leak--I'd suggest replacing the MC. Hopefully, Bill V will respond as he, like many others, has much experience with the brake system.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-13-2009, 10:06 AM
Also, I see a competitor has a "performance upgrade" 23mm direct bolt in M/C available to replace the 19mm. Looks like the 19mm core that has been bored over with 23mm guts... I'm still using the steel M calipers...
Matt
Old 06-13-2009, 01:33 PM
What method do you use for bleeding them?
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 06-13-2009, 07:01 PM
Hey Matt,
Sounds to me like your MC needs to be replaced, especially if its old...
I'd recommend sticking with the 19mm one as the 23mm version is really only for people using 4-piston calipers that require the additional fluid displacement.
Pressure bleeding is the only way to properly bleed/flush these systems.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-13-2009, 07:39 PM
FPB111's Avatar
If you are going to replace it use a 23mm. The 23 will require more pressure for the same brake force, it is like stepping on a brick, but it will not get soft on the track.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 06-13-2009, 07:40 PM
The M/C was replaced with a rebuilt core at the time. I suppose it's possible it was not a good one from off the shelf.
I usually use the two person method. However, I recently broke down and borrowed a buddy's pressure bleeder, fearing my wife was trying to collect the insurance...
Matt
Old 06-14-2009, 05:56 AM
JMHO, but rebuilding and/or installing used MC's is really a bad idea. After 40+ years, I've never had any luck with rebuilt MC's and now I always replace them.
I don't think thats the best place to save money,.......
Save up some dough and get yourself a Motive bleeder. This will be FAR cheaper than buying a new MC every few years,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-14-2009, 10:45 AM
The MC was an OEM piece. I just assumed it was rebuilt. Came in an ATE box with literature, etc... Same unit goes for $230 now, so I don't really feel like I skimped...
I'm going to see what the warranty was. Seems like it was 1 year, which has passed.
Yes, I'm going to get a bleeder with this order. Thanks for the nudge.
I'll post back after replacement of the M/C with a verdict.
Matt
Old 06-14-2009, 11:26 AM
AutoBahned
RWebb's Avatar
re: skimped
That isn't it -- but there is a chance that even a brand new quality m/c will be ruined if the brakes are pumped too enthusiastically for bleeding.
That is one reason people pressure bleed - but only one.
A $10 garden sprayer maks a fine pressure bleeder -- add a hole to a brake cap and glue an adapter in there; connect the hoses and you are done.
When finished spray your garden, or spray stain onto your deck or fence.
Buy another $10 sprayer in the winter in 2 years; lather rinse repeat.
Old 06-14-2009, 12:53 PM
