Help with 15/7 n 15/8 wheels
Hi All, Has anyone here install 15/7 front and 15/8 rear wheels with 205/55/15 tires? On early 911 1969-1972 LWB. If so, please input your thoughts? Pics of the set up would be appreciated as well. The good, the bad and not too. Thanks in advance!
Old 01-12-2024, 12:29 PM
Backspace are 4 7/8” front and 5 1/8” rear
Old 01-12-2024, 01:11 PM
Bill Verburg's Avatar
Not quite
For 15" Fuchs
7 has a f/s of 74.5mm(2.93") and backspace of 121mm(7.7"), ET is 23.3mm
8 has a f/s of 99.9mm(3.93") and b/s of 121mm(4.77"), RT is 10.6mm
for 911 fitment of these wheels only the f/s is a concern and there only for 8s in back
The 8ET10.6 has a front space that wants SC/Carrera flares which a '69-72 lacks
7s fit the front fine but the 8s will require sever ride height restrictions because of the front space spec
even 7s in back will want a tire shorter than a 215/60
Bill Verburg
Old 01-13-2024, 07:09 AM
Hey Bill, thanks for the input, seem like a tuff fit.
Old 01-15-2024, 12:52 AM
The ones I used to run are stamped 6 JX15 with 205x50's. These were on a '67 with no problem. They measure 7" but am assuming the 6" accounts for the bead. Your problem is going to be tire choice. I only had two for the 16"s I'm running now.
Old 01-15-2024, 03:08 PM
PCA Member since 1988
You measure the rim width from the inside to inside.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-15-2024, 11:23 PM
This is the spec of wheels from seller:
The front rims are 6” wide from inner bead to inner bead, 7” wide overall with a backspacing of 4 7/8”
The rear rims are 7” wide from inner bead to inner bead, 8” wide overall with a backspacing of 5 1/8”
All 4 tires are Dunlop Direzza 205/55 R15
I know the 205/55 R15 will fit into my stock 72 body, as it came with 205’s
Old 01-15-2024, 11:47 PM
So what you have are 6 & 7's
the 6's are ET36 the 7's areET49
205/55 is a good choice
205/60 is a tad taller
205/50 is shorter
The 7s will want spacers for use in back no matter what tire is chosen and if they are the wheels I suspect them to be will also need inner tubes
the size of the spacers wanted will depend on the tire chosen, you could use 225/50 or 215/60 or the 205s used on the 6s each will want a different spacer thickness
if using 215/60 on the 7s that will also want a 185/70 or 195/60 on the front 6's
there is also a good chance that the fronts are also tube tube too
to determine whether these are tube type or not look at the wheel profile
no safety bead - tube type
a composite pic, tubeless w/ safety bead on left, tube type w/o safety bead on right
all these are tube less
Bill Verburg
Old 01-16-2024, 04:09 AM
[QUOTE=Bill Verburg;12172319]So what you have are 6 & 7's
Bill, here a picture of the backspace front and rear, as the seller measure. On rear 7” would it be somewhere at ET26-28 offset on 5 1/8” as he measure? In that case, would it still need spacers? Or am I wrong on my backspace est?
Old 01-16-2024, 01:53 PM
Old 01-16-2024, 01:55 PM
Can't tell a thing from those pics
here are the relevant facts, front space isn't listed but its the normal distance from wheel mounting face to the plane of the front lip, basically the same as backspace but going in the opposite direction
Bill Verburg
Old 01-16-2024, 02:58 PM
First picture is the rear wheel, showing 5 1/8” backspace
My est backspace is ET 26-28? You had it at ET49, correct me if I’m wrong?
Second picture is front wheel, showing at 4 7/8” backspace
Old 01-16-2024, 04:27 PM
a length measure needs 2 ends I only see 1 and that at an angle so I can't tell for sure.
assuming your #s are right here's what you are looking at
old is at or near the widest I've seen on a n/b 911, new is what you are looking at
there are 3 different common lip specs that affect the specs, old Fuchs, BBS and new std,
the first time I ran the #s I used Fuchs specs which are also what is used in the old section here, It appears that you are looking at steel wheels in this table I arbitrarily use the new std lip spec which may or may not be what is actually there, But it does appear to ne new spec because the lip width(say 6) appears to be 1" greater than the bead spec(7))
So all these specs are +/- a bit depending on the lip spec
Bill Verburg
Old 01-17-2024, 06:33 AM
Dave Kost's Avatar
https://www.willtheyfit.com
Try this site.
Dave K
Old 01-17-2024, 07:26 AM
