(the shotguns)
berettafan's Avatar
Wheel bearing dust cover tool....
Snap-On GCP10.
Saw Matt DiMaria (well respected p-car wrench in the DC area) use this when trouble shooting a bearing issue i had.
Just an FYI for anyone struggling with these things.
Old 06-05-2009, 08:57 AM
Noel's Avatar
I use the claw end of my hammer and work my way around. Never had an issue after 8 years of doing this.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 06-05-2009, 10:15 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
2" muffler bracket is the best method I have found for these, and it costs about $2 at any local auto parts store.
1981 SC ROW Coupe
Old 06-05-2009, 11:06 AM
I ROC!
mpeastend's Avatar
I have seen cars at the track with nuts mig welded onto the end of the dustcap. A threaded rod or bolt can then be screwed on to rock the cap off with only your hand [as long as bolt is about 5-6 inches long. Alternatively, you could also use a slide hammer attached to the threaded rod, but that's overkill.
Old 06-05-2009, 11:38 AM
(the shotguns)
berettafan's Avatar
been using a catspaw myself (similar to a hammer claw) but after repeated adjustments the cap is getting a bit tore up. this should prove to be MUCH easier.
Old 06-05-2009, 02:08 PM
kodioneill's Avatar
LARGE channel locks works for me.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-05-2009, 03:19 PM
I've actually BROKEN a slide hammer getting one off a 930, the one with the nut already attached, and requiring this because of how recessed the cap fits on a 930 ......talk about insanely and ridiculously TIGHT !!!
Muffler clamp works well for 911's....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-13-2009, 06:50 PM
(the shotguns)
berettafan's Avatar
Well I've discovered the useful part is the curved handle. Works very well!
Old 06-13-2009, 08:47 PM
burgermeister's Avatar
+1
That (and a claw hammer) works like a charm.
And it was $1.28
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 06-14-2009, 07:33 AM
deathpunk dan's Avatar
large flat blade screwdriver and hammer at 9 and 3 o'clock.
Sepia brown 1971 911T.
Old 06-14-2009, 08:32 AM
Less brakes, more gas!
euro911sc's Avatar
Geez... I just use what ever piece of scrap wood is laying about at the time...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-14-2009, 09:34 AM
barney911rs's Avatar
Big Channel Locks for me.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 06-14-2009, 08:13 PM
Senior Advisor
James Brown's Avatar
Perfect and other uses also!!
/Users/jamesbro/Desktop/images.jpeg
08 Cayenne Turbo
Old 06-16-2009, 09:22 AM
175K911's Avatar
I've had that tool for 20 years, and rarely use it. Large channel locks work so much better.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 06-16-2009, 09:24 AM
Senior Advisor
wooops here you go
08 Cayenne Turbo
Old 06-16-2009, 09:25 AM
jbrand540's Avatar
+1 works like a champ and it is cheap
'89 Carrera Cabrio
'01 Audi A6 2.7t
'01 BMW 540i
'06 Dodge Ram 2500 Diesel
+2 Muffler clamp
Old 06-16-2009, 09:32 AM
safe's Avatar
bfh
Magnus
Old 06-16-2009, 11:23 AM
