Guest
Posts: n/a
964 Steerin Pumps
They are known to be a problem area in this series. Is it the pump itself that fails, or is it that the seals in the pump leak? Any permanent solutions to the problem? Thanks in advance for the replies.
[This message has been edited by Gus Berges (edited 01-22-2001).] [This message has been edited by Gus Berges (edited 01-22-2001).] |
Guest
Posts: n/a
I removed the pump and it still leaks. That is one of this weeks projects.
Guest
Posts: n/a
I believe the most common problem is with the seals.
