power window
Is it normal that I can't operate my passenger's power window with my driver's switch when the passenger's switch is disconnected?
Old 06-18-2009, 08:16 AM
Wash. State
nesslar's Avatar
I'm quite sure. Should be like a 3-way switch, say at the top and bottom of a stairwell. I have the wiring diagram at home, but you should be able to find it here by searching and then you'll see.
Old 06-18-2009, 09:09 AM
power window
Thanks, you're right. Just found the diagram...
Old 06-18-2009, 09:45 AM
I had a bad passenger's window switch, and I could not operate the window until I replaced it. I tried putting the good switch from the driver's door in the passenger's door, and no go! After reading the wiring diagram, I determined both switches have to be good AND connected for either switch to work. At least this is the way it went for me.
'77 911S
'72 BMW 3.0 CSL
Old 06-18-2009, 10:18 AM
