964 hose routing question
Putting a '91 3.6 in a '90 C2 and have one hose that I'm not sure where it goes. It is #40 in the picture. I have #41 coming from the oil tank to right behind the rear center of the motor where it hooks into a clamp, but after that, i dont know where it goes. Or basically, what does # 40 connect to?
Thanks.. http://forums.pelicanparts.com/uploa...1245377876.jpg |
#40 is an oil tank vent , goes to the intake manifold top side of the throttle body , the fitting faces left towards the driver's side .under the bell crank.
OK, thanks, i didnt see a fitting there, but ill look again tomorrow. This is a small, maybe 7/16 inch hose. The two big ones, 31 and 37, also from the oil tank, connect near there also, and 31 comes in at a right angle as you described as well. In this picture, you can see where the two big ones go.
http://forums.pelicanparts.com/uploa...1245384398.jpg |
Ok, I got it. Thanks! The picture diagram is obviously not to scale and misleading!!
| All times are GMT -8. The time now is 04:47 PM. |
