Insert Tag Line HERE.....
rattlsnak's Avatar
964 hose routing question
Putting a '91 3.6 in a '90 C2 and have one hose that I'm not sure where it goes. It is #40 in the picture. I have #41 coming from the oil tank to right behind the rear center of the motor where it hooks into a clamp, but after that, i dont know where it goes. Or basically, what does # 40 connect to?
Thanks..
Old 06-18-2009, 07:19 PM
#40 is an oil tank vent , goes to the intake manifold top side of the throttle body , the fitting faces left towards the driver's side .under the bell crank.
Turbo Werks Inc.
Palm Beach, FL
Old 06-18-2009, 07:58 PM
rattlsnak's Avatar
OK, thanks, i didnt see a fitting there, but ill look again tomorrow. This is a small, maybe 7/16 inch hose. The two big ones, 31 and 37, also from the oil tank, connect near there also, and 31 comes in at a right angle as you described as well. In this picture, you can see where the two big ones go.
Old 06-18-2009, 09:07 PM
rattlsnak's Avatar
Ok, I got it. Thanks! The picture diagram is obviously not to scale and misleading!!
Old 06-19-2009, 08:30 AM
