papi's Avatar
1977 911s Leaking Fuel
I started my 911s up after being in storage for two years, but have a fairly severe leak that I could use some help on.
Start up procedure:
1) New Bosch Battery
2) Added 10 qrts of oil
From the beginning gas was leaking beneath the fuel cell. I plan on taking out the tank tomorrow, but wanted to pulse the board first on what might be the cause of the leak. Any help would be greatly appreciated.
-papi
papi
1977 911s Targa
1968 R60/2 BMW Mcycle
1969 R69s BMW Mcycle
Old 06-18-2009, 09:38 PM
Max Sluiter
Flieger's Avatar
I would tend to think your old rubber fuel lines have dried up and deteriorated. The lines nearest the tank are bhind a lot of other structures and can be a real pain to replace, though.
Old 06-18-2009, 11:05 PM
Rouxzy's Avatar
Papi,
Had the same issue with my '77. The fuel pump is under your tank covered by a skid plate. Remove the plate and you will see the pump. Mine was leaking from the line where it connected to the pump. The line was old and brittle. I ended up replacing the line.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 06-19-2009, 12:13 AM
