-   -   parts arriving this week; need to know which to install first: (http://forums.pelicanparts.com/porsche-911-technical-forum/48091-parts-arriving-week-need-know-install-first.html)
adamnitti 01-25-2001 02:25 PM
i ordered new ball cup socket, shift bushing, and shift coupler bushings last week... is there a particular order i should install these to insure a greater level of success?
also, if anyone has any hints related to these, i sure would appreciate it.
thanks-
Adam Nitti
ajnitti@mindspring.com
www.adamnitti.com
'85 911 Carrera Coupe
'89 Jeep Cherokee... 277,000 miles, no rebuilds!!!
Early_S_Man 01-25-2001 03:40 PM
Adam,
The ball cup and shift rod bushings should be done first, with plenty of moly grease. Be sure to mark the shifter housing and tunnel with spots of paint, so it can be put back in the same position.
Next, the coupler position on the shift rod should be marked with paint before the pinch bolt and set screw are loosened. A large bench vise and two sockets, one with a smaller OD than the cross-pin, and another with ID larger than the pin, can be used to remove the cross-pin and bushings. The new bushings are installed dry, and there is supposed to be some (1-2 mm) longitudinal play of the pin within the bushings, but no measureable axial play.
With the shifter and coupler installed in their original positions, no adjustment may be needed, or the amount will be small.
Warren Hall
1973 911S Targa
86ragtop 01-25-2001 05:05 PM
Adam
feel I should chip -in as it is one of the few jobs I have tackled with some success!.
The only things I will add or reiterate to what warren wrote are to DEFINATELY mark the where the pinch bolt tightens on to the shift rod as this is where I messed up!.
Trying to adjust and find that same spot again is vague.
I believe I have found it but believe I have no 'rotational play'.
No one has yet confirmed exactly where this play should be?.
On the gear stick?
If there is no play on the gear stick, is this detremental to the tranny?
Anyone?
thanks Ben
Oh yeah , and plenty of grease! http://www.pelicanparts.com/ultimate/smile.gif
adamnitti 01-25-2001 09:01 PM
thanks, guys-
i'm gonna print this out and make sure to follow your position marking instructions closely...
you know-a-i'll-a-come-a-hollerin' if i get myself into trouble!!!!!
(this bbs rocks my face)
Adam Nitti
www.adamnitti.com
'00 murray lawn tractor, 6sp, 42" cut...
patalive 01-26-2001 04:52 AM
Hey Adam! - -
Forget the Carrera! Let's get that 6 spd Murray rocking. Check out this site for the next race nearest you.
http://www.letsmow.com/
http://www.pelicanparts.com/ultimate/biggrin.gif
Chuck
83SC
adamnitti 01-26-2001 06:11 AM
lawnmowers doing 60mph?????????????
wow, patalive, thanks for the tip!!!! i've got to see this!
Adam Nitti
www.adamnitti.com
