mackgoo
Guest
Posts: n/a
Build up
Just put the induction on today, ran the fuel lines to the injectors and set the injection pump timing. Any way is there a torque spec for the injectors, as well as what washers are used under the injectors?
A while ago there was a spat of MFI questions on the board it all ended pointing to a source that ends up being right here at Pelican. In that documentation it gave a less than Germanic scientific procedure for setting correlation etc. Has any one followed that procedure with success?
Old 01-26-2001, 12:54 PM
Early_S_Man
Guest
Posts: n/a
Bruce,
Those copper sealing rings are 12 mm ID, and 15.5 mm OD -- DIN 7603 Cu
The torque values are 3.0 m-kg (22 lb-ft) for the injector into the head, and 1.0 m-kg (7.2 lb-ft) for the flare-nuts on the lines at the pump and injectors.
Warren Hall
1973 911S Targa
Old 01-26-2001, 02:14 PM
