Clutch Question
I know this has been discussed in the past...but I didn't find anything to help me decide.
Clutch....Stock or Power?
Matt. 83 911SC 85.5 944 NA - Sold |
Air Medal or two
You mean Hydraulic ?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
No. Sorry if I was too short.
Sachs standard or power clutch.
Schleprock
Depends on your intended use. Street use, stock is more than capable. Track use, the power clutch with alloy housing is nice for quicker rev-matching/throttle blips.
Whatever the case, there's no need to spend big bucks on a 911 clutch kit. The factory-spec'd clutch assembly is a very good set of components.
Kevin L '86 Carrera "Larry" |
