OK, project for the day is changing transsmision-fluid on my 930.
I have: * 4 liters of 75W90 synthetic GL-5 tranny fluid (should be 3,7 liters in tranny?) * 17-mm hex tool for undoing the oil-plug (is this right dimension for the plug? it's the bigest hex-plug i could buy) I'm planning to: * Lift the car at the shop * Try to loosen fill-plug first, so i don't need to tow the car in case it's stuck. * Losen drain-plug with a 17-mm hex bit and stand clear. * Screw in drain-plug and torque it tightly "by hand" without overdoing it. * Fill up oil trough fill-hole with small bottle (will bottle fit??) Questions: * Is it 17-mm hex bit i need to loosen drain-plug?? * Where is filling hole? On the drivers side? * Are there any spec-tools involved that i should know about? * Will this also change oil in diferential or is diff "drainable" as well? I know i should lift the car and take a look, but there is no lift near my garage... Thanx as always! )
