Guest
Posts: n/a
suspension alignment
WHAT ARE THE BEST NUMBERS FOR THE ALIGNMENT FOR STREET USE. TOE IN/ TOE OUT, CAMBER, HEIGHT, ETC...
I HAVE TURBO TIE RODS, WLETMEISTER BUSHINGS, 195/60/15 FR AND 215/60/15 RR. AND MY CAR IS A NARROW BODY. TKS FOR ANY REPLIES.... |
Guest
Posts: n/a
specs are: front: Camber 0 deg neg +- 10 min Caster 6 degrees 5 min. +- 15 min Toe-in +15 min +- 5 min (not pressed) Rear: Camber 1 deg negitive +- 10 min Toe-in +10 min +- 10 min. These are the factory specs - good luck. 81'SC
Guest
Posts: n/a
Check out this good article in the Tech section. http://www.pelicanparts.com/techarticles/911_alignment_tips/911_alignment_tips.htm
------------------ 8 9 9 1 1, The last of the line. |
Guest
Posts: n/a
Tks guys for the info.
