Guest
Posts: n/a
Heated washer nozzels
i recently removed my screen washers nozzels to clear a blockage, i was surprised to note two wires connected to it, is this for heating of the nozzel?. if so how is it operated. My car is a 87 carrera.
------------------ mike 87 coupe' |
Guest
Posts: n/a
According to my Porsche Parts & Technical Manual, they operate when the ignition is on.
They should be wired to a switched power source. Hope this helps. ------------------ Cary Kutter 77 Carrera w/3.2 Rennlist #001117-2266 PCA Region - Big Sky [This message has been edited by cary (edited 01-31-2001).] |
Guest
Posts: n/a
They probably work off of your rear window defrost switch. i.e. When you defrost your rear window, your washers heat up to help you clear your windshield.
Just a guess from my VW GTI... ------------------ Dave 1970 914-6 (soon GT) |
