AutoBahned
Chemicals You Should Have
thought it would be useful to collect a compilation of chemicals one should have on hand (in stock) to DIY work on your Pcar...
organized by task; please post links to good threads as you add to this my start: Electrical Contacts: PPG - I have this & assume it is good ProGold - was sold for high end stereo contacts Dielectric Grease - for all wiping or fixed contacts; connection pressure displaces the grease from the contact area - {search for the terms and name Jim Sims for more info} 10% acetic acid solution (very strong vinegar) - soak a corroded electrical contact in this for a day or two to magically clean and brighten [search for the terms + Sherwood for more info] - if not in your grocery outlets, you can mix this up by getting film photography chemicals (Kodak) and diluting as appropriate Loosening Seized Fasteners: CRC now has a product called "Freeze-Off" - seems to work pb Blaster - effective but stinks Kroil - I like this one; not a tinker Wurth also makes a product ---> I tend to spray these products indiscriminately at known "muthas" (fasteners that are typically hard to loosen) whenever I am under the car; if I eventually have to remove the fasteners, my hope is that it will be a lot easier... note: WD-40 is not a penetrant - use it for water displacement and rust protection Lubricants: Wurth HHS for door hinges, latches, sliders on the seat & etc. Swepco Chain Lube in a rattle spray can - got to be good, eh? [let's avoid piling on here re motor oils and trans. lubes...] Protectants: Gibbs Corrosion Block Boeshield T-9 -- good enuff for aircraft, so... Tecty - Grady likes this waxy protectant for Mg and other parts, and it was used by Porsche AG but it is hard (impossible) to find in DIY sizes Antiseize: - for lug nuts, Porsche specified a particular Optimolloy in a TSB - rather than keep both silver and Cu based ones around, why not just use the Cu based one everywhere (??) - any reason not to? - you can also buy the easy to use stick forms now from Loctite Fastener Locking & Bedding Compounds: - Loctite has whatever you want - I hear they bought out Permatex, so maybe they are identical now... Purple - the lowest strength; I use it all over just to prevent vibration (a long held paranoia of mine from way back when I smashed a VW bus all over the Oregon deserts) Blue - hand tool removal Blue" - forget the stock #, but this one will work even w/o haviung to use their special cleaner on the threads Green - same level as Blue, but will seep into threads after the fastener is installed. I use it after I torque a fastener, tho it really shouldn't matter, see paranoia comment above Red - rarely used; requires heat to break the seal and permit fastener removal Last edited by RWebb; 06-28-2009 at 10:49 AM.. |
Isn't beer a lubricant???
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
Great post!
What dielectric grease does pelican sell? Link?
Also, I cannot seem to find POR 15
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
I would add:
Rust Treatments 1-Naval Jelly, Rust Mort, or other spead on wash off Rust killer; 2-Extend or other Spray on rust converter/primer coat; and 3-POR 15 (for those who like it) Cleaners 1-Brake Cleaner 2-Carb Cleaner 3-Mineral Spirits (or Stoddard Solvent) Adhesives 1-JB Weld 2-2 part epoxy 3-3m Weather strip adhesive Lubricants 1-Triflow lube
Don't have anything to add to the chemical list but I do strongly recommend folks get some blue nitrile gloves whenever using these products.
AutoBahned
good idea
Harry - I use TriFlow on locks - is that where you use it? also, rust converter also known as "rust reducer" |
I use Triflow on other, hard reach places where I need light lubrication. The rollers on the windows, the joints and mechanism on my Targa Top are two that leap to mind. Also, we also should have a can of light oil for lubing Bell cranks in the throttle linkage etc.
I was going to mention the same thing. I have a number of these mentioned above and have found myself using gloves more and more even just clean the windows or wax the car. I also will thrown on a surgical type mask to filter half the crap out before I breath it all in as well. THere is somethign to be said about breathing in all the fumes etc. WD40 cant be all that good in your lungs.......
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
A surgical type mask will not remove the toxic parts of the fumes. Only a chemical rated respirator may be effective and even then you are not sure. your best bet as a DIY'er is to work in a well ventilated place and minimize the quantity you expose yourself to. I totally agree nthe Nitrile/rubber gloves. I use them for just about all of my work around the house and car now. I like the minimum cleanup when I am done.
Lots of POR 15 outlets on the Net. My last can came from a Pontiac restoration outfit in Fullerton that happens to be a distributor. Even at that, I had it shipped, what? 30 miles?
AutoBahned
any FLAPS for the dielectric grease
"Only a chemical rated respirator may be effective and even then you are not sure. " - yes, and then there's skin absorption... |
Dow Corning 112 is a great high-temperature silicone based lubricant/sealant I use on O-Rings & brake caliper rebuilds. You'll probably have to buy it off the internet somewhere, but one tube (150g) should probably last you a lifetime unless you do this sort of thing for a living.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
And then there is "good ole" Bosch Distribitor Grease for those of us who still have points. One tube will last several lifetimes.
UNDER CONSTRUCTION!
i use corrosion X and this stuff works great. they make a penetrant and a sealer to put on battery connections and anything you dont want to rust .
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
abides.
Along those lines, I keep a can of battery acid neutralizer spray which I use whenever I have a battery out or when corrosion forms on the terminals. I wish my PO's had used it a little more often
![]() I also have an aerosol can of white lithium grease. Pretty handy for getting at mechanisms inside the doors or other hard to reach areas without having to disassemble everything.
Graham 1984 Carrera Targa |
I always keep a gallon of fast evaporating wash laquer thinner for cleaning certain things.
Randy,
Thanks for the storable list. I might add; motorcycle chain lube spray. The lube is sprayed onto the target with a solvent carrier that, once evaporated, leaves behind a relatively viscous high-strength grease for those hard to lube, infrequently serviced locations such as the window mechanism, pivot joints, etc. Lithium-based grease is water-soluble, so watch out if the mechanism is exposed to weather or road splash. Sherwood |
AutoBahned
sure Sherwood, I thought it would be useful to collect all this info...
for m/c chain grease, I use the Swepco chain lube (above) for brake caliper rebuilds, I use the magic Porsche brake paste - forget the exact info on it tho, but dealer will have it. It comes in a little brown jar like a snake oil herbal salve... Bosch Distributor Grease (sqeeze tube) is great for clutch pivot bushing bearing shaft and the other stuff thereabouts. |
Interesting thread. Subscribing.
1984 Targa |
I would add 3M General Adhesive Remover
![]() You can also list Gibbs under penetrating oil. The Wurth product is Rustoff - really good stuff.
Robert Williams 70' 911T |
