82SC
Guest
Posts: n/a
Weirdo Speedo
Hey guys my speedo is acting pretty weird.
At a stand still the speedo is at zero, as I pull away, it stays at zero, then around 15mph, it surges up to 15, then works normally...any suggestions???
MJ
Old 02-02-2001, 01:14 PM
josh912
Guest
Posts: n/a
Your speedo is probably sticking. I have the same problem with my tach. What I do is just tap the gauge. The only way I can think of permanently fixing it is to disassemble the speedo and clean it up. Good luck!
Old 02-02-2001, 04:34 PM
lagoon
Guest
Posts: n/a
have the same problem with mine only reads 0 until i am at 30 mph, them jumps up. Any ideas, pass it along. 81'SC
Old 02-02-2001, 05:07 PM
IDrabble
Guest
Posts: n/a
I had the same problem with my Rev. counter, just took the glass out, sprayed in a light oil (GT90 in the UK, dont know for the states) and no problems. This was a year ago and still going strong
82sc
Old 02-03-2001, 05:53 AM
Jens Wendorff
Guest
Posts: n/a
Had the same with the tach.
Opened it, cleaned it, applied a bit of new (thin) grease.
Worked for about a year perfectly. This winter, below 10°C, the problem is back
The spare tach I have starts with the same symptoms now...
Jens
Old 02-04-2001, 07:45 AM
