Vacuum Advance Question
I've got 1973 911T that I bought recently. Hasn't been running in several years (due to body/chassis issue, not engine). In doing a once-over getting ready to try and start the engine, I found several vacuum caps that were cracked, etc. but I also saw that the vacuum advance cannister on the distributor was hooked up to a hose that ran to the manifold below the carburetor.
I thought that the vacuum advance should be connected to the carburetor vacuum fitting, that usually runs to a port just above the butterfly when shut, right?
My thinking is that the engine doesn't need any additional advance at idle, but under part-throttle load, which is what the carb-vacuum port should do.
Sorry to bother - if I had a manual I would have just looked, but haven't found one yet.
Thanks for the help!
Dealer for Cibie & other Period Fog/Driving Lights, brackets, Corbeau Seats, Fuchs, Torque Thrust, Minilite, Coromodora and other Period Alloy Replica Wheels
GregGearHead com
Ask me about Replica Fuchs (Even Deep 6 & 7R) wheels!
Old 07-06-2009, 11:56 AM
moneymanager's Avatar
Someone will correct me if I'm wrong, but I seem to remember this is a vacuum retard in 73, not advance. All the advance is I believe mechanical and controlled by the weights. The vacuum retard serves only to bring the idle down quickly to save gas and emissions.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-06-2009, 12:13 PM
AH. That would make more sense. Silly me. Thanks for the help.
GregGearHead com
Old 07-06-2009, 12:59 PM
early_s_man/Warren said only the factory carbed engines had vac advance
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-06-2009, 03:23 PM
Yep - mine was CIS converted, so that is probably right. Glad I asked before trying to start her up.
GregGearHead com
Old 07-06-2009, 03:26 PM
Bland
unclebilly's Avatar
at idle you have max vacuum. Under full throttle you have little vacuum. Placement of the line above the buttelfly makes no sense.
Old 07-06-2009, 03:38 PM
