-   -   Just for fun: How often do you add a quart? (http://forums.pelicanparts.com/porsche-911-technical-forum/483346-just-fun-how-often-do-you-add-quart.html)
Davie Boy 07-02-2009 07:16 PM
I've always been curious. Haven't you? I'll start us off:
  • I've got a '71 T that's got good leakage/burnage. I add a quart about every 300 miles. :eek:
  • I've also got a '90 964 C2. It does a little better. Until recently (it's in the shop for some repairs), I've had to add a quart about every 800 miles. :rolleyes:
Whatchoo got?
ZAMIRZ 07-02-2009 07:25 PM
My 3.0 liter used to sip...I'd add a quart every 2500 miles.
New 3.3 is in break-in period right now, but so far I haven't had to add any in 600 miles or so. I expect this one to drink a little bit more oil though.
wildcat077 07-02-2009 07:28 PM
Going on 2500 kms with my 89 3.2 and haven't added any yet,even though i get a few oil spots in my driveway and a whiff of Mobil 1 at traffic lights...
kidrock 07-02-2009 07:32 PM
1500 miles, knock on wood.
aigel 07-02-2009 07:54 PM
No oil added between changes here.
George
PCA7GGR 07-02-2009 08:15 PM
When it stops leaking... ;>)
Embraer 07-02-2009 08:17 PM
my 3.0 required no oil between 3000 mile changes.
cjares 07-02-2009 08:40 PM
my 3.2L does not require oil between changes.
ischmitz 07-02-2009 09:31 PM
Either nothing or maybe one quart between oil changes on a rebuilt '91 964.
Alan Lindquist 07-02-2009 09:56 PM
3.0 Oil Usage
I have an 80 SC with very little compression in cylinder #2 - but the others are balanced and healthy. The case leaks from several places - I get about a tablespoon per week on the drip pan but I'm sure that I'm dripping more than that under running conditions, as indicated by the smoking tail at stoplights. It's unfortunate, but I'm not ready to replace the motor with a 3.2. Right now, I get about 1500 to 1800 miles on a quart which is pretty good considering the dead cylinder and the leakage.
Drew001 07-02-2009 10:09 PM
Same here.
MT930 07-02-2009 10:17 PM
Half to quarter qt every 3000 Miles between changes.
tvanbroekhoven 07-03-2009 04:20 AM
Nothing between changes. *also knock on wood* :D
JoeyD911 07-03-2009 05:24 AM
3500 miles on fresh 3.0 top to bottom rebuild. Drove from Long Island NY to Key West Fl. after the break in oil came out. Brought 3 qts of oil, 3 qts came home. Still nothing added!
burgermeister 07-03-2009 05:27 AM
1 qt / 800 miles. Some leaks, some burns. 154K miles.
More during track usage.
JP911 07-03-2009 08:53 AM
With Mobil-1 I burned a quart every 1K.
With Swepco I'm not burning any oil between changes.
Bob S 07-03-2009 09:24 AM
Mobil -1 , none between changes
janz 07-03-2009 09:47 AM
"86" 3.2 odometer has 145,000 I use a quart or less every 2,000 to 3,000 miles.
steely 07-03-2009 10:36 AM
I was jus' wondering about that this very morning.
I haven't had a chance to run her much due to the rain or our schedule, but I took a ride this morning and was a little surprised/dismayed at the size of the wet spot I saw on the garage floor.
I have to check - I've put maybe 600 miles on her this season, and the oil gauge is showing halfway.
3.2Carrera 07-03-2009 11:31 AM
it depends on how i drive the car. If i am sitting in L.A traffic and its hot out, plus some spirited driving will mean i need to add a quart every 800 miles, just driving highway means a add a quart every 1000-1500, not too bad.
