al lkosmal's Avatar
71 qtr window hinge/mounting screws?
Getting down to the short strokes on my 71E. I don't know why i can't seem to find this info, but can anyone tell me what hardware is used to install the quarter windows. I/E. the hinge to body screws and washers. Drawing a blank as I sift through my treasure trove of zinc plated fasteners.
Pix are good too!
Regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 06-28-2009, 11:29 AM
Zeke's Avatar
The info is here somewhere because I answered that question once before and a few others have as well. Thing is, I can't always remember. I think it's flat head Phillips, 4mm dia. I usually get the pitch wrong, but it's a popular one like .7. It's not real long, but goes into a hollow space. So try a 4 x .7 x 14mm or 16mm.
Old 06-28-2009, 02:56 PM
joefrantz's Avatar
Just did this recently.
The B pillar attachments are M5x8mm allen head bolts with an M5 flat washer.
The rear hinge attaches to the window frame with 2 M4 x 6mm flat head screws, and the hinge attaches to the C pillar with 3 M4 x 15mm flat head screws.
There is also a triangular plastic spacer that goes under the C pillar mount. It's about 3-4 millimeters thick. If you're not using the spacer you may want to go a few millimeters shorter on the C pillar screws.
Joe
Joe Frantz
73 911 T
Old 06-28-2009, 03:47 PM
Zeke's Avatar
Good on you, Joe. I'll recommend this for the Wiki.
Old 06-29-2009, 07:45 AM
al lkosmal's Avatar
Joe,
Thanks for that info. Just what I needed.
Regards,
al
RGruppe #669
Old 07-04-2009, 06:52 PM
al lkosmal's Avatar
Joe,
Regards,
al
RGruppe #669
Old 07-04-2009, 09:48 PM
