Wink Wtb
Need short wiring harness which is on the main harness for 1982 911 3.0L Targa. I had been working on the wirng harness in my car, when I noticed that the short harness which sits next to the Jetronic ECU going towards the front of the car was missing. The white plug has 6 wires, and I am hoping that I won't have to fabricate this harness to make whatever it connects to work! I am not sure if this small harness is year specific. The harness has this color coded wires:
Rd/wht
Brn
Blk/wht
Blk/rd (tied together)
Rd
Old 07-03-2009, 04:42 PM
There is a specific Pelican forum for WtB and FS used cars and parts, and you'd probably have more success there.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-03-2009, 05:00 PM
There is a VW relay that plugs into the system in the area youre looking. If you look it up, its the Llambda relay.
Bruce
Old 07-03-2009, 05:32 PM
Thanks guys! You are right as always. I just couldn't find a way to put this WTB add in the proper Forum, so I wound up putting it here. Sorry. I will try to place it correctly next time.
Old 07-04-2009, 08:37 AM
grateful user
don gilbert's Avatar
you need to get the correct bosche metal relay from pelican. the cheap plastic 5 pin parts store relay will not work. I would not drive the car hard until corrected. Your freqency valvle is inop without the relay, and the F/valve provideds enrichment at wot. without it, you are chancing a very lean situation at wot(not good)
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-04-2009, 09:37 AM
