gt3racerich's Avatar
Question Ballpark cost of a 3.6 conversion in a 73 911
I know there are many variables but what would a good motor go for and how much to do the conversion. I am pretty handy and would do what ever I could myself.
Again, just looking for a ballpark figure.
Thanks, Rich
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant.
Old 07-02-2009, 08:28 AM
Elombard's Avatar
Check at Dr. Timmins website, I think you can get the conversion "kit" for ~$10K not including the motor.
I think if you can weld a bit and re-use some used parts you can save quite a bit. Others who no more will be more helpful.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-02-2009, 08:54 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
An engine will probably cost in the neighborhood of $7-10k, and figure at least a few thousand extra to ensure that you can tie up any loose ends... thats you doing all the work. With a 3.6 you will absolutely need to add a front oil cooler, and you [U]really[U] should do a complete brake upgrade, and probably some suspension tweaks as well.
Old 07-02-2009, 08:59 AM
Kevin Stewart's Avatar
ill sell you all the parts with a motor that was rebuilt with 200 miles 13750, includes every thing including headers oil cooler etc etc stew09@aol.com 574-274-2543
Old 07-02-2009, 09:04 AM
DW SD's Avatar
$15k w/ motor if you do the work yourself. Closer to $20k if you pay a shop. Full cooling system is about $2k. conversion parts are several $k.
Doug
1971 RSR - interpretation
Old 07-02-2009, 09:32 AM
Thanks for the info guys. Unsure at this piont what I am going to do.
Rich
Old 07-05-2009, 10:10 AM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
+1 what smokintr6 said, it's not just the engine its the transmision, suspension, brakes, and oil cooling as well. It really just doesn't seem to end.
For example, I just had to upgrade to Carrera axles and CV flanges on mine.
Any shortcomming your 911 has, the 3.6 will shed light on it.
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 07-05-2009, 11:17 AM
if you use it as a street car you really dont need to upgrade brakes and stuff unless you track it, Kevin
Old 07-05-2009, 11:22 AM
ToddM's Avatar
Depends on where and how you drive it, Kevin
Something like beefing up the transmision and axles are cheap insurance to reduce possibility premature failure in a 3.6 conversion
-Todd
Old 07-05-2009, 11:36 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Doug
That's about what I was thinking - probably $16k-$17k if you do everything yourself and maybe $22k-$23k if a shop does it.
If you want a "built" 3.6L it'd go up from there (or thereabouts).
Ultimately performance is measured not in horsepower or ft-lbs of torque, but in terms of cubic dollars.
Black Cars Matter
Old 07-05-2009, 01:14 PM
