964 decklid
Trying to take apart decklid for painting. After removing the allen screws at the pivot points there's the plastic air screen which looks to be attached to the upper shell. Any help would be appreciated.
Vince |
Senior Advisor
it all comes apart kind of a puzzle. the hardest part is seperaiting the wing bezel from the wing. its glued on pretty good, try not to break it. (remove it for painting)
08 Cayenne Turbo |
I couldn't figure out how to seperate the glued 2 piece wing without destroying it.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Senior Advisor
pull on a corner and slowly the glue will give way. go slow and work your way around the frame. to reattach it use a marine adhesive like sitkaflex
08 Cayenne Turbo |
ok.. thx
was scared to do that without advise so I painted it attached
I'll give it a try.
Thanks Vince |
