-   -   Caster/camber/toe tool vs. alignment shop (http://forums.pelicanparts.com/porsche-911-technical-forum/483728-caster-camber-toe-tool-vs-alignment-shop.html)
pjo046 07-05-2009 01:49 PM
I need to have my front end aligned, as I did a renovation on the front suspension this winter/spring. However, the next winter I will be renovating the rear-end, which means I need a new alignment next year. Taking several trips to an alignment shop is quite costly, so my question is this:
Can one achieve good results by using a tool like this one?
http://cgi.ebay.com/ebaymotors/CAMBER-CASTER-TOE-GAUGE-ALIGNMENT-RACING-AUTOCROSS-NEW_W0QQcmdZViewItemQQ_trkparmsZQ7c293Q3a1Q7c294Q3 a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem3e f5a6c447QQitemZ270409319495QQptZMotorsQ5fAutomotiv eQ5fTools
Or is this not accurate enough without having turn-plates? Has anyone used tools like this with success?
jason2guy 07-05-2009 01:54 PM
ive done the home alignment. to get it right its pretty time consuming, but doable. yes thats one of the tools youll need, or its equivalent.
burgermeister 07-05-2009 04:58 PM
You could just get a digital angle finder from Harbor Freight for $20. With a straight piece of wood or aluminum, it becomes a great camber gage. Because the 911 strut is coaxial with the kingpin, you can just hold it to the strut to measure caster (though it is a PITA to get it attached). For toe, you can make blocks that register against the tire, use strings, or get a HF toe gage (all <$20).
docrodg 07-06-2009 05:17 AM
The key is to get wiggle plates for the tires to sit on. Do the front first, then put the plates on the rear. Remember to bounce the suspension a few times before each reading.
BK911 07-06-2009 06:19 AM
You could make your own alignment rack. Search for alignment. Here are two threads to get you started:
http://forums.pelicanparts.com/porsche-911-technical-forum/80904-home-alignment.html?highlight=alignment
http://forums.pelicanparts.com/porsche-911-technical-forum/329363-4-wheel-alignment.html?highlight=alignment
cgarr 07-06-2009 06:39 AM
Really not much you can do with the caster and the camber is easy to set along with toe.
