Caster/camber/toe tool vs. alignment shop
I need to have my front end aligned, as I did a renovation on the front suspension this winter/spring. However, the next winter I will be renovating the rear-end, which means I need a new alignment next year. Taking several trips to an alignment shop is quite costly, so my question is this:
Can one achieve good results by using a tool like this one? Or is this not accurate enough without having turn-plates? Has anyone used tools like this with success? |
ive done the home alignment. to get it right its pretty time consuming, but doable. yes thats one of the tools youll need, or its equivalent.
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
You could just get a digital angle finder from Harbor Freight for $20. With a straight piece of wood or aluminum, it becomes a great camber gage. Because the 911 strut is coaxial with the kingpin, you can just hold it to the strut to measure caster (though it is a PITA to get it attached). For toe, you can make blocks that register against the tire, use strings, or get a HF toe gage (all <$20).
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
The key is to get wiggle plates for the tires to sit on. Do the front first, then put the plates on the rear. Remember to bounce the suspension a few times before each reading.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
Home of the Whopper
You could make your own alignment rack. Search for alignment. Here are two threads to get you started:
Home alignment 4 Wheel Alignment
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
abit off center
Really not much you can do with the caster and the camber is easy to set along with toe.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
