Trigger mech drivers door
Help! Trigger mech drivers door lock (RHD) won't work. Have had good look at it, can't see anything obviously wrong. Any suggestions, anyone??
Old 08-07-2009, 02:26 PM
SLR SLR is offline
SLR
Yep having similar problem as well. As you may have seen my post just before you. you will need to pull the door panels off (not hard) and "this is fiddley" remove the door handle and the latch bar. Now that most of mechanism is exposed, lube it all up as well as the window regulator.
Tools needed, BEER
Old 08-08-2009, 01:27 AM
E Sully's Avatar
My trigger was barely working. After close examination I found the trigger had a crack by the roll pin. I purchased this part PEL-TMP-TRIG-C. It wasn't a great fit, but was able to combine it with the parts from the original and now it works well.
Old 08-08-2009, 05:45 AM
