-   -   Are the nuts supposed to be different? (http://forums.pelicanparts.com/porsche-911-technical-forum/48381-nuts-supposed-different.html)
atr911 02-07-2001 12:42 PM
Check this out, is there something wrong with the following pictures. Are those sprockets supposed to be different? I was looking at Andersons' book and noted they should be the same. Any ideas? Thanks (again)
Adam
http://www.cyberbeach.net/~roseneck/rightcam.jpg
http://www.cyberbeach.net/~roseneck/leftcam.jpg
atr911@hotmail.com
Early_S_Man 02-07-2001 01:12 PM
Adam,
Well, somebody used two different 'vintages' of cams in your engine! The right cam is a post-'80.5 cam and uses a 12 mm bolt to hold the sprocket, and the left one is a pre-'80.5 cam using the 46 mm nut. Does look a little odd, doesn't it?
Warren Hall
1973 911S Targa
