How to shift a 901 on the bench?
I want to run my 901 through all the gears while on the bench. How can I shift it on the bench?
I would rather be driving
Mount the shift coupler in place. Should easily select all gears. The other option is to clamp a vice grip on the input selector shaft.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I was gonna ask if I could just put a vise grip on there with a protective foam. I don't have a spare coupler. Right now transmission is in neutral. What direction am I going to shift around the 5 speed?
Slumlord
Vice grip with emery cloth underneath.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
