Nickshu
Guest
Posts: n/a
Timing Advancement
Im about to tackle the tensioner upgrade on my 82 SC. I have heard of people advancing the timing to (I think) 1.4mm BTDC for better performance.
I was wondering what reference point you use to do this?
What are the performance results? Does this produce a difference throughout or only at certain RPM's?
Thanks in advance for your replies!
Nick Shumaker.
__________
Nick Shumaker
1982 911SC Coupe
[This message has been edited by Nickshu (edited 02-07-2001).]
Old 02-07-2001, 08:55 AM
Early_S_Man
Guest
Posts: n/a
Nick,
I don't think you really want to do that! Assuming a 'middle' setting, here is what the possible changes are, and the results:
Advance the cams to 1.4 mm, emphasis goes to the top end, and you lose bottom-end torque!
Retard the cams to 0.9 mm, and you increase bottom-end torque.
But, since your '82 is supposed to be set at 1.0 mm (halfway between 0.9 mm and 1.1 mm) already, you would lose a lot of bottom-end responsiveness!!! You could set it at 0.9 mm for a slight increase, but I'm not sure it is worth the trouble if you find both sides already at 1.0 mm. Maybe just leaving it alone is the way to go.
Warren Hall
1973 911S Targa
Old 02-07-2001, 10:41 AM
Nickshu
Guest
Posts: n/a
Warren, thanks alot for the info. I think I'll just leave it alone. But, just for knowledge, what are the reference points used to advance/retard the timing?
Thanks again.
Nick.
__________
Nick Shumaker
1982 911SC Coupe
Old 02-07-2001, 12:49 PM
Early_S_Man
Guest
Posts: n/a
Nick,
The Z1 mark on the crankshaft pulley. You turn the engine over until the distributor rotor is pointing at #1 or #4. Mount, preload by 0.5", and zero the dial indicator on the intake valve retainer, then turn the crank pulley a full 360 degrees and Z1 is lined up again ... that is the TDC 'overlap point' where both intake and exhaust valves are open a small amount. At this point you read the lift value for comparison with the spec book value.
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 02-07-2001).]
Old 02-07-2001, 01:05 PM
Nickshu
Guest
Posts: n/a
Thanks again Warren.
Nick.
__________
Nick Shumaker
1982 911SC Coupe
Old 02-07-2001, 03:22 PM
BRAINIAC
Guest
Posts: n/a
Warren, you made a mistake on the above post. Advancing cam timing will increase bottom end. Retarding cams will increase top end. I know you know that. I'm just pointing out that you got them backwards. I know it's counterintuitive, so I'll forgive you.
Tyson Schmidt
72 911 Cabriolet
[This message has been edited by BRAINIAC (edited 02-07-2001).]
Old 02-07-2001, 04:23 PM
Nickshu
Guest
Posts: n/a
I thought that sounded a little wierd, but being inferior in knowledge to Warren, didn't want to say anything.
Thanks Tyson!
Nick.
__________
Nick Shumaker
1982 911SC Coupe
Old 02-07-2001, 06:26 PM
Early_S_Man
Guest
Posts: n/a
Yes, Tyson, I did ... just call it brain fade while working on three things at once!
And, just two months ago, a mysterious power loss was attributed to a change to retarded cam timing after a tensioner replacement in the following thread:
http://www.pelicanparts.com/ultimate/Forum3/HTML/004283.html
So, Nick, you may want to reset the timing after all! This is one of those rare cases where I disagree with Bruce Anderson's beliefs!
Warren Hall
1973 911S Targa
Old 02-07-2001, 06:35 PM
