Dyno run update....
Put the car on the dyno today to have the ECU remapped and sorted out.
204 rwhp.....this is comparable to a holden V8 5ltr with worked head mild cams and exhaust. on this dyno.... So I am quite happy with this. Especially since the rev limiter cut in before the power died. limiter is set to 7,200 but engine is built for 8,000. It's a daily driver so looking for longevity not screaming death...! 3.0 78 SC 10.5:1 JE's GE80 cam twin plug ITB's - Injection Perfection EMS Stinger ECU Lightened flywheel ARP rod bolts Comp springs SSI's Monty 1 x 4" out Could have put a smaller cam in it to smoth the curve out in the lower regions. Over 4K is where this thing needs to be driven to show of the potential of the engine. Cheers Mark........ |
Sounds like a real street rocket Mark.
Photo's?
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
